Need help, engine doesn't rev past 4200rpm
grimwookie
Car: 1993 Nissan Hardbody d21 2.4L
I bought a '93 d21 hardbody last June,(2008) and ever since i got it it hasn't revved past 4200 rpm, its an auto trans, I've changed the fuel filter, the transmission fluid, and tested the sensors, nothing helped. Can anyone help?
Otto.
Wrong section.
hachiroku781
Car: 1997 Nissan Maxima GXE
i wasnt aware that trannys revved. well i guess they do if i f*** them harder. they scream louder.
Red coupe
Car: 92 Nissan 240sx Coupe
Sounds like safe mode from MAF error? I know you tested sensors, but does that include this one?
Kinda just a random guess.. like was said before, people in the truck section or the section for the engine the car has could probably do a better job.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Moved to the truck section for you.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
What have you tested so far?
RT22
Car: 1991 nissan hardbody
Why would you want to rev past 4200 no power up there.
seang
Car: Ford Fiesta ST
I hit 6200 when I need to. Peak torque for the truck version of the ka24e is 152 lb ft at 4400rpm, and 134hp at 5600 rpm, rev limiter is somewhere around 6800, but IDK, I've never ran into it. I'd say a 6200 shift is max if its running right. My max shift points are 1st gear=24-28mph, 2nd gear=43mph, 3rd=57mph, 4th=84mph, and 5th to the top speed of 97mph, drag limited. You can tell the engine is busy when revving this high, but its got the guts thats for sure. Forged steel crank, forged steel con rods, dual valve springs, everything else is pretty good.
I'm not telling tall tales, and I definitely save the forays to redline for special occasions, such as merging into heavy traffic, and other situations where it just wouldn't be as safe not to try and go for it. It can be a pussycat when I can get away with it. I don't always wind it up that far.
s13_240_rb20
Car: 1990 240sx RB20DET
I see how old this thread is, but I have a similar problem and I think I saw seang still commenting recently on here...so here goes:
Did you ever manage to reach a higher top end than 97mph? I have an engine in my truck that can beat the crap out of wind-drag but feels like it tops out around 85mph.
Does anyone know if my HF37 rear axle in my 1993 hardbody is maxxed out under 100mph? I would also like everyone to post their fastest top end speeds in their hardbody and be sure to state your year, model, auto/5sp, and axle information pleeeeeaaaasssseee.
TJ
longtooth
Car: 89 d21 HB
When I bought my 89 back in 89 I got it upto 100 mph but that was years ago and it took along time to get there and it really wasnt designed to go that fast so I never did it again.
Also my 4 cylinder seems to loose power/vibrate over 4500 rpm so I use 4200 rpm as a shift point.
moneymike
Car: 1991 nissan d21 hardbody
ive gotten my all motor up to 91 then got pulled over im sure i could have gotten more out of her
on boost ive taken it up to about 95 before letting off, now im looking into getting a new transmission made for boost and 6 speed.
i have a 91 5 speed ext cab on boost with many mods
