91q45v8 wrote:He says The passenger seat won’t move.
Check all the fuses, if the airbag light blinks too its a blown fuse. But the air bag light blinks it could be for other reasons too obliviously.
91q45v8 wrote:the heat control display doesn’t work.
You need new (Which cost a but load from IOS AKA Infiniti of Scottsdale) used or you can have Jerry tucker repair it for $100. You can also try to repair it your self by following this guide:
zerothread/804
91q45v8 wrote:The antenna for the radio does not go up.
You might need a whole antenna assembly or just an antenna if the previous owner removed it.
91q45v8 wrote:The rear passenger window doesn’t work.
You might need a rear window motor which is expected of a vehicle of this age, or it could just be the switch in the center console or the rear window switch too. If either switch fails the window will not move.
91q45v8 wrote:Also the power steering isn’t working right, the wheel turns hard (it has speed variance control which is electronic) so I think maybe the computer relay is bad. What is the problem, does it could it be a bad relay or are these problems independent.
Is the reservoir full?
Does the speedometer work correctly?
Does the car have TCS AKA Traction Control?
Welcome to NICO.
