Need Help Electrical problem
93jdirty'
Car: 1993 Infiniti J30
My dad got me some led windsheild washer lights so i continued to wire them to the side signal lamp. all of a sudden i must of shorted something out because all the ligths on the exterior dont work.When i turn on the first click (running lights) nothing turns on. When i turn on the second click(headlamp lowbeam) the high beam comes on.the brake and reverse light is the only exterior lights that are working normaly, i tryed to replace the headlamp relay and it didnt change anything exept making the pasenger side head light not work entierly. Note: this all happend instantly and everything was normal until i spliced the corner light wires, also the HID kit is not installed yet.. any ideas, i might have to find a auto electriction
Modified by 93jdirty' at 3:41 PM 8/27/2007
driverdriver
Car: NICO's longtime resident Canuck!!!
I'm thinking its fuse related.
93jdirty'
BUMPP any ideas guys im stuck
yodawill2000
Car: 94 Infiniti J30
Like driver said .Its either a blown fuse or maybe some fried wiring.Kinda hard to tell if its not in front of us
gotspeed
Car: 96 nissan pathfinder 97 infiniti J30
check your fuses first and go back and check all the wiring that you have installed and make sure everything is grounded and that there are no open wires touching anything. Its something that you have done wrong because the problem was not there until you installed those lights. Just back track your work.
93jdirty'
ive checked everything i know of so far and came up with nothing im just trying to get some posible solutions to the problem. i know some auto light specialest, the guys who wire up the the light bars for state cars and strobes i think i may have them give it a run though and see what hapens
