need help, desperate
A.Grittler
Car: z32
i know you guys dealt with this many times, but im really desperate, spend weeks trying to work it out...
so, error code 34 :gapteeth: :gotme
knock sensor problem...
my ecu shows 0.568ohm
knock sensor shows 0.580ohm
so i would assume i need new knock sensor
but i bought two (so i have 3 all together, mine old one and two new ones)
bought both not from ebay, from proper shop, one for 85£ another for 160£
and both shows freaking 0.560-0580ohm
put 1meg ohm resistor
like it say in here
http://www.zhome.com/ZCMnL/PICS/detonat ... ensor.html
same code 34
so that is it?
:gotme :confused: :wtf2:
thank you
Z32 TT 1991 ATM
NolimitZ32
Bad harness?
A.Grittler
Car: z32
this is that i thought, so one day i got bit crazy
i got to ecu, found knock sensor wire, took all out, cut it and replaced with my own😋
so all new wirring...and still same 34 😬
NolimitZ32
I meant the sub-harness that goes between the EFI harness plug and the knock sensor. Is your knock sensor in the factory location in the block valley?
