EW »
https://forums.nicoclub.com/ew-u28959.html
Tue Feb 12, 2008 7:02 am
Yes, you need to run 2 pair of RCAs to the amp. For the best sound, you should run 16ga or larger speaker wire directly to the new speakers. Sometimes running speaker wire into the doors is a biatch so many people will connect to the factory wires in the dash instead. If you connect to the factory wiring, it also makes reinstalling the factory deck easier. If your car has a factory amp on the rear deck, you can connect to the speaker wiring there. There will not be a night and day difference in audio quality by running new wire to all the speakers but it is the best way to do it. I would run a third RCA to the trunk so if you ad a sub amp you will be ready to hook it up without taking the car apart again.
Modified by EW at 12:35 PM 2/12/2008
