99QX4 wrote:How did you get the code, because if you had it scanned I would assume it would tell you which one it is. I have a bad O2 sensor too but when i had it scanned it told me which sensor. Unfortunately i don't think i wrote down which code it was though, but i'll check right now. I'm not sure if you can do it yourself, i don't know what's involved. I'm having the guys at my dad's diesel truck change mine soon. But i also heard that you can't just change one, that you have to change them all...can anybody help me/us out with that one?
edit: i do have the code but it's not the same as yours. My code was P0158 which is bank 2 sensor 2 (at least you can eliminate that one!)
nah you dont have to replace all 4. and the scanner doesnt really tell you much that i would rely on besides the code. i had a p0160, replaced the drivers side rear o2, reset the SES light, had the ECU flashed, now its good to go.
http://www.nissanhelp.com/Owne...3.htm
that lists 4 diff codes for bank 2 sensor 2 but im assuming its different problems with that particular sensor....but remember mines an '02 with the vq35, but still an R50. i think thats for all R50's but correct me if im wrong.
