Need help choosing wheel size for my 04 G35x
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
albert3029
Car: Infiniti G35x 2004
What's up guys, thinking about buying some rims for my 04 g35x. Was thinking about going with 18's then drop the car with the 350Z springs, since it's only an inch of a drop. Went on another forum and was told to get 19's or 20's. May not need a drop if I go with the 20's. But I'm worried I may lose the comfort of the ride if I go that big. Also want the staggered look. If i get an offset of 35 front and 43 rear, will this be a perfect fit with the 20's (staggered). Someone mentioned that a fuse will have to be removed, what fuse can they be possibly talking about?
Thanks in advance for the feed back.
audtatious
The taller the rim, the less sidewall you will have. This will result in a rougher ride. My suggestion is to first determine what "look" you want. 20" rims will fit and the offsets you list would probably be OK (someone validate please). Regardless of the rim you choose you will still have the same wheel gap and the only way to get rid of that is to lower the car.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
