Need help choosing tires for my new wheels....
sr20power
Car: S14 Zenki
Well i just bought the Works XD-9's 17x9.5 +17 for all 4 corners...
Friend is suggesting 235/45 all around
I'm thinking 215/45 or 215/40 all around (need to have a slight stretch...)
Any input will be taken into consideration
Thank you in advance...
P.S.
Yokata180sx...what you think?
Soravia
Car: 2003 Audi A4 1.8T
Google 9.5 inche to milimeterI would go with 245 at the least. 17x8 can take 225 easily, 235 on 9.5 would be stretched and increase the risk of damaged rims.You'll need to roll fenders.
BTW, go to https://www.tiresavings.com/ti...s.com and try these Riken Raptor ZRs
Then let me know how they perform compared to Nitto 450.
Thanks
sr20power
Car: S14 Zenki
Right now i have the FN's 17x9 in the back with 225/45's and its barely a stretch...
I need a bit more stretch to clear some issues with the coilovers.
Thanks for your input tho
Soravia
Nice wheels and tires on both cars.
9.5 inches is 241mm and with the lip of rim it would be 250mm or so. With 215mm pot holes and curb rash could damage your wheel lips instead of being absorbed by the tires.I would say try putting on some used tires from a store for the looks and order that size.
sr20power
Car: S14 Zenki
Soravia wrote:Nice wheels and tires on both cars.
Thanks you the compliment...can't wait to get the Work's on
Soravia
Oh, just got mail from a Cougar guy.Quote »Hi Louis,
All I can say is so far I am very happy with them. They look real nice and are very sticky for cornering and quiet on top of it. The Kumho tires don’t last long as I have heard. The AVS sport tires are very good but you will pay for it. For the best bang for the buck I would jump at the Rikens.
Mark[/quote]
sr20power
Car: S14 Zenki
Sweet good to know...the Work's will be my daily driving wheels. The Rikens is at a very nice price compared to the Hankook RS's. The FN's with Azenis is getting costly for autoX'ing and daily driving...
Thanks for the tip...i'll let you know how they are if i decide to get them
Soravia
Don't forget to post pics in the tire and wheel fitment thread. I'll be posting mine as soon as I get the Raptors at the local store for $65 a piece. (225/50/16)
sr20power
Car: S14 Zenki
Thanks....I will eventually post both my wheels up, as soon as I get my digital camera back from my friend.
sr20power
Car: S14 Zenki
weekend bump...
Any other suggestions...?
Cameron
Car: a 240
tiresavings.com and get the Federal Runway 916's 245/40
sr20power
Car: S14 Zenki
Are 245/40's going to have a slight stretch on a 9.5in wheel...? I have 225/45's on a 9in wheel and its barely a stretch on it....
Okay...215/45 or 215/40 is going to be a bit much of a stretch, so now i'm thinking 225/45's or 225/40's....
Need some help here, or i guess i'll just have to do it the hard way...just buy them and figure it out on my own....
boriquaS13
Car: 92 240sx
Id go with 225/40 all the way around I wish I did when I bought my tires I went with 235's not enough stretch. Btw it was on 17x9 + 17's
sr20power
Car: S14 Zenki
boriquaS13 wrote:Id go with 225/40 all the way around I wish I did when I bought my tires I went with 235's not enough stretch. Btw it was on 17x9 + 17's
Not enough stretch...I barely see any stretch with 225 on a 9in. From what I know so far is that on an 8in 225/45 is a perfect fit. And having the same size tire on a 9in is barely a noticeable stretch. I know that my new wheels are 0.5in wider, but 225's is going to be a difference much...? Is the reason why my initial thought was 215's all around.
So confused...
gumby74
Just out of curiosity, what exactly do you consider a stretch?I have a pair of 17x9.5 with 245/40 tires. There is about an inch of sidewall to either side of the tread. That is a stretch. The bead protector barely covers the inside lip of the wheel. Dunlop suggests a 9.5 as the max for a 245/40, therefore that is what I suggest.
sr20power
Car: S14 Zenki
I can't post pics of what i would like on my friends computer. But can you post a pic of your setup. I've been searching around and can't find any good pics with 9.5in wheel....
As I said in the 1st post that my friend is suggesting 235/45's all around but from my experience with 225/45 on a 9in, won't seem like much of a stretch with 235/45 on a 9.5 wheel...
can you post a pic with your setup...want to see what it would lool like...
thank you
Cameron
Car: a 240
y you want a stretch btw? are you running a really slammed susp, or somethin...?
sr20power
Car: S14 Zenki
ZenkiCam wrote:y you want a stretch btw? are you running a really slammed susp, or somethin...?
I like the look and also cuz i'm having so called problems (maybe) with the way the coilovers are....
The right side coilover's spring perch is right above the rim, where as the left side is about 1/2in sitting above the rim. With my new wheels being 9.5in wide, which brings the wheel a 1/2in closer to the coilover i might have rubbing issue with the tire on the right side. I'm still working on the suspension to see if something is bent or not.
So if i have a bit of stretch in the tire it won't be so close to the spring perch.
I'll probably go with 235/40 all around for tire size....
yokota180sx
Car: 1997 Stagea RS4, r34 front
either one will look fantastic
sr20power
Car: S14 Zenki
yokota180sx wrote:225/35215/40
By any chance you have a pic of that tire size...? I believe I read somewhere that you had these wheels or a friend of yours have them on a S13....
I have been searching around for awhile now but can't get any good pics w/ a 9.5in wheel...the most i've seen so far is 235/40
yokota180sx
i have pic sof a 225 on a 9 but it wont be much different
215/45 on a 9j
215/40 is too big on a 9j IMOlooks funnya 225/35 or even 215/35 would work better IMO
sr20power
Car: S14 Zenki
okay....a bit confused here
Are those picture w/ a 225/35 or 215/45..?
Thanks for the pics and help...
yokota180sx
its a 215/45
I run a 225/35 or 215/40i have a 215/40 on my cedric, ill get a pic tonight
the 215/40 on a 9.5 will look good
boriquaS13
Car: 92 240sx
Just go with what yokota said he knows his stuff about rims and tires.
215/40 FTW
sr20power
Car: S14 Zenki
yokota180sx wrote:its a 215/45
Okay thanks for the help...Pics of the 215/40 will help alot. Getting alot of conflicting input that a 215 won't fit or can't be done on a 9.5in wheel. A tire place that i go to says he will put that size on, but doesn't recommend it.
Just want to make sure i don't damage my new babies by not having enough meat to protect them.
Soravia
How much did you pay for the wheels?
If the tires won't clear why not just roll up the fenders than trying to get a stretch?Or you could just sell the wheels and get a little less in size.Either way your rubber is going to be the one to touch the ground.If you get into a curb-rash like I just did this afternoon on a tight U-turn, the blings wheels with stretch tires won't be so blings anymore, don't forget that.
sr20power
Car: S14 Zenki
Soravia wrote:How much did you pay for the wheel?
About $1500....
Soravia wrote:If the tires won't clear why not just roll up the fenders than trying to get a stretch?Or you could just sell the wheels and get a little less in size.Either way your rubber is going to be the one to touch the ground.If you get into a curb-rash like I just did this afternoon on a tight U-turn, the blings wheels with stretch tires won't be so blings anymore, don't forget that.
My problem isn't clearing the fenders, its about clearing the SPRING PERCH on the right side. And selling the wheels is NOT an option for me. Regardless of the problems i have...I WILL MAKE THEM FIT.
I'm not worried about curb rash....what I'm worried about if 215/40 is going to be enough tire with potholes, overpasses or aggressive driving. That the tire won't un-bead or blow-out.
yokota180sx
dude you can fit itit will be like butter
just use a federal ss595 and it goes on like silkthe wheel shop i buy all my wheels from said i couldnt put a 225/40 on a 10ji did and hteuy were like Whoa
sr20power
Car: S14 Zenki
By chance you got that pic yokota180sx....?
I'm curious with that size tire on your cedric, are we talking about driving like a grandma...lol Being careful about EVERY little bump or something...? Would really like to see 215/40 on a 9.5 wheel
yokota180sx wrote:just use a federal ss595 and it goes on like silkthe wheel shop i buy all my wheels from said i couldnt put a 225/40 on a 10ji did and hteuy were like Whoa
You put the tire on yourself? Can of hairspray technique or something along those lines....?
yokota180sx
nah dudei drive the **** out of my car
I have a pic on my phone, but it will be a while befor ei can post it
seiriouslyyou will be fine with a 215/40 on your 9.5i swaer yuo will
I have access to a tire machinei install and remove al lmy tires
and federals dont even need help stretchingI put a 15/40 and a 25/40 on the 9 and 10j with only a slight bit of help with one hand to start the bead.
it was like silk man
