Need help choosing spacers
BMAR240SX
Car: 1993 Nissan 240S Coupe
I have a set of rims that are 16x8 with 38+ offset with a set of falken 512's 225/50 all around. I have Stance Gr +pro Coilovers and Tien Tie rods I am wondering if i am going to need spacers to clear everything so i do not rub or if i will be fine. I looked in the database and most the rims that were close to my size did not have spacers but i would just like someones opinion that is more wise when it comes to this
Thanks Bryan
BMAR240SX
No one can give me a hand =(
BMAR240SX
Anyone?
94_240sx
Car: 94_240SX
My setup is this.
GR+ Pro17x8 +38 all the way around235/40 Falken 615s
No, wheels and tires won't rub since Stance coilovers have better clearance than others. I put 15mm spacers along with Nismo extended studs because wheels were sunken. If I were you, I'd put some spacers to make wheels flush with the fenders. I have Ichiba spacers and I highly recommend them.
Not sure about your setup, but I had to roll rear fenders, not pulling.
BMAR240SX
O sweet so i guess i can skimp out on it for now and do some more maintenance
Where did you purchase the extended studs and spacers?
94_240sx
Car: 94_240SX
BMAR240SX wrote:O sweet so i guess i can skimp out on it for now and do some more maintenance
Cool, man.Nismo studs(60mm) from Courtesy Nissan(http://www.courtesyparts.com) and Ichiba spacers from Ichiba USA(http://ichibausa.com).
BMAR240SX
Thanks you the man lol
ss82480
Car: 1992 240sx Coupe
+1 I been running nismo studs + ichiba spacers for over a year now.
BMAR240SX
Is there a difference in that setup and the other set up where it comes as one piece that you bolt onto your factory studs
ss82480
well first off I wouldn't use the studs that Ichiba provides you. I used them and was able to to spin them after install... not good.
94_240sx
Car: 94_240SX
ss82480 wrote:well first off I wouldn't use the studs that Ichiba provides you. I used them and was able to to spin them after install... not good.
Very good point. Actually, one of members in vert forum crashed his vert on the highway because Ichiba studs snapped. You want ARP or Nismo studs for sure. Stud is one of those parts you should never cheap out.
Ichiba spacers are good quality though. They are hub centric, so there's no vibration or shaking at high speed. I highly recommend them. Studs came with them anyway, but just throw them away.
BMAR240SX
Wow that tab will be pricey i got some saving to do, i rather have something that will last and do a great job that risk my life. Thanks for your help and feedback guys
BMAR240SX
Well the tires are rubbing on the coilovers =(
I am trying to figure out a solution but idk what to do
94_240sx
Car: 94_240SX
BMAR240SX wrote:Well the tires are rubbing on the coilovers =(
Man, sorry to hear that. I think your tire is a little too fat. My tire is perfectly squre when it's mounted. Do you think 5mm spacers will clear it? You can use 5mm spacers with stock studs.
BMAR240SX
I think imma need like a set of 15mm all around, cause i expect to go lower and i know that is not going to clear
BMAR240SX
I am going to be getting a set of peak performance studs and some spacers for a good price from a friend so i will see how that goes, hopefully everything clears and i can lower the car
BMAR240SX
Alright guys I know you said bolt on spacers are bad but what do you think of H&R spacers I can get 2 15mm spacers for 240 which I think is a good price. What do you think?
