I would say $2K - $2.5K. The under plenum hoses are shot also, and the suspension rubber is hard as rock candy. You are looking at about $5K there unless you are adept with the tools and have them and the time. Then you are still in for at least $3K for parts. How does the ATF and PS look? R12 for the AC is not inexpensive. And I would want to see that car on a lift and check out the corrosion from being in NY, One of my G50 is from Brooklyn, but it was only used to go into the city for dinner as the owner had a city car.thejfed wrote:Again, not trying to start anything. I've read the facts and agree, clearly they shouldn't have been plastic.
So for a perfect condition 1990 Q w/ 63k on the clock, what's a reasonable asking price.....one owner. They want $6k. That's absurd considering I'll probably have to get the guides done...
...and a BOATLOAD of ragsOwnerCS wrote:...Looking back at last year, I easily spent $3,000 on parts. That amount included the purchase of new Phase II injectors, alternator (Nissan reman) all new hoses, chain guides, O2 sensors, knock sensors, knock sensor wiring harness, transmission filters and hoses, seals, gaskets, water pump, belts, power steering hoses..
Or the ABS system which is spendy. Make sure it has the under engine tray.Infinitiguy19 wrote:Black fluid in the Master Cylinder reservoir that is also a little low means a full fluid replacement with a possible replacement of brake pads.
I agree. Anyone who knows these cars would run the hell away once you see those wheels and the big emblem. Personally I'd never think of anything older than 94.BadQ45t wrote:It is very clean but I bet it sits on that lot for awhile. Given gas prices and the color of the car, it will not fly off that lot.
That is not to mention the airbags which only have a lifespan of 10 years, the control units and wire connections all over the car.maxnix wrote:Or the ABS system which is spendy. Make sure it has the under engine tray.
I would want a cash kitty of $10K just to feel safe.
I drove my 1995 from Brooklyn to Seattle. Great drive once I got out of Chicago. It had 26K and was 6 years old.
