need help car wont start
1991s13coupe
Ka24de/auto/150k
Car ran fine untill one of the injector went out. Got it relpace and thats when car wont start. With the fuel rail prop about 1/2 inch away from manifold you can see fuel squirting from all 4 injectors and the motor will be running. Motor dies as soon as you seat the rail back onto the manifold.
There is spark from all 4 plugs but its yellowish.
Fuel pump is good i got about a 1qt. of fuel coming from the return line (key at the on start positon)
Items I have changed:
*4 injectors
*ignition coil
*temp sensor
*4 spark plugs (cap/rotor/wires all ok)
*starter
*mass air flow
Help...
