Soravia wrote:If you didn't have the engine turn when you jumped the car before it could be the started. If the engine turned and won't start (and the fuel and spark is fine) check the plug from ignition to distributor, check the Mass Air Flow sensor plug next to Air Filter box.
it will turn, checked the MAF sensor it is connected, i will check the starter and the plug from the distributer tomorrow. thanks for the help , anything else i should check? trying to make a list of what to check for tomorrow.
