loystock »
https://forums.nicoclub.com/loystock-u10145.html
Sun Jul 19, 2009 7:57 pm
Without knowing the history of the car, it may not be easy diagnosing current and future problems with it. Check the vehicle security system. Close the hood and trunk and then lock all the doors. The Security lamp should be steady for @ 30 seconds (pre-armed phase) and then start flashing every 2.5 seconds or so (armed phase). If not, you have a problem with the security system. It's also possible that the key you have are not recognized by the ECM which prevents you from starting the car (NATS).
The dash lights are only powered when the ignition switch is in ON or START. They must turn off when the switch is OFF or key is pulled out. There could be a problem with your ignition switch circuit.
Please download a copy of the FSM (Factory Service Manual) and go to EL (Electrical; Systems) chapter and look at the wiring diagram.
