need help car running rough and overheating
jfizzle001
Car: nissan 240sx
the car keeps overheating after i drive for 5-10 min and it runs rough. i bought the car and all it needed was an alternator and it started right up drove it home and it was fine. the drive was like 30 miles. when i got it home i replaced the distributor, wires ,plugs. it ran alot smoother than before but it still bogged down at abot 2000 to 3000 rpm then it started overheating so i replaced the thermostat but it still overheats. im going to replace the radiator this week. but i would like to know what it could be.
ka-t_2_be
My overheating problem was just air in the system. Try bleeding your coolant lines and see if it changes anything.
S13FASTBACKSR
Car: '92 Fastback SR powered
explain how it runs rough..also any smoking? ..let us know when you replace the radiator and if that solved the problem..dont forget you have to open the system when putting fluid in or else you will have an air bubble and still be overheating...because of an air bubble
jfizzle001
Car: nissan 240sx
by rough i mean it pops occassionally and there is no acceleration after about 2-3k rmp it bogs down and hesitates. there is no smoke
VeLiduS
Car: 92 240sx
Im having the exact same problem first with the overheating but i found the faulty hose that was letting air into the system. So no overheating but the bogging and hesitating in the same range 2-3k sometimes little sometimes it sounds like its gonna shut down but after that its strong like its perfect. What could be the prob? its got new plugs and wires.. is it fuel filter or...? give me some ideas . Im gonna do fuel filter cap and rotor soon i guess anyway. its a 91 ka and ive seen other posts asking about hesistation and bogging in the same area but no real leads yet..
thanks for yer time
club240sucks
Car: 93 touring FD
my car is doing the same thing, i bought wires, plugs, fuel filter after i dropped the new engine in it, and it only has 70k, when i put the new engine in i put a new clutch, radiator, of course all fluids, and its only been in for a week now, and i dont know what my problem is, i was thinking MAF or TPS
S13FASTBACKSR
jfizzle the overheating problem and hesitating/no power/bogging could be 2 different problems..the overheating you may have an air bubble in your system...the other problems..check your tps voltage first..spark plug gap..and hows your timing?
club240sucks
Car: 93 touring FD
i just thought of something else..... ****ty Catalytic Converter... im gunna chop mine off tomorrow and see if it runs right.. ill let ya know
