KASilvia90 »
https://forums.nicoclub.com/kasilvia90-u28447.html
Tue Jan 09, 2007 12:48 am
The mechanic who said the pistons being "in the wrong spot" is very wrong, is bad at explaining problems or doesnt understand timing well. If your running on 3cylinders your car will kinda have a harley sound on acceleration (how they have an audible sputter/miss) and feel real weak.
Its hard to diagnose that, there can be many problems. It sounds kind of like a Crank Angle Sensor, mine acted similiar for a while. The car kind of loses its timing and the fuel/spark come at really random inconsistant times.
According to the factory service manual, things to look at are:MAF, Coolant Temp Sensor/Switch, Fuel Pressure Regulator.
Thats not everything but at least a start. And just because it cranks, doesnt mean it isnt eletrical. It just means your starter and battery are fine. What do you mean spark plug cap, do you mean spark plug or like spark plug wire boot? and what did the "odd bird" look like.
It also kind of sounds the throttle position sensor isnt working right or disconnected. I dont know about the 5-speed but when my car was auto, the tps got disconnected and it was just really nuts to drive in the rain (random shifting on apex's with bald tires FTW!).
Hope that helps some. If theres anything else you can add, definatly do it. That is unfortunatly a common problem with many things that can cause it, and the little things are better at determining it.
