Need Help - Ca18DET
campground man
Car: 1990 Ca18det B12 Sentra
I just swapped a CA18DET into my car. I'm using a ca18de computer with NIstune and the image map for CA18DET loaded onto it's chip. I am also using a Z32 MAF. I started it for the first time last nite and it idles very erratically. It's like someone is giving it gas then letting off over and over. When I touch the gas pedal it doesn't effect the idle either just continues reving and letting off on it's own over and over.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
try swapping MAF's... DSMs do that sometimes... trust me, i know
lostmenoggin
Car: 1989 Nissan 240sx ca18det swapped
how do you like the NIStune? I've been contemplating that myself..
float_6969
If you have a stock CA image loaded onto the map and it's not reprogrammed for the Z32 mafs, you're going to have problems. It needs to know that you're using the Z32 MAFS.
campground man
Any clue how to do this with Nistune?
