SureShot »
https://forums.nicoclub.com/sureshot-u49088.html
Thu Jul 03, 2008 5:35 am
yes, the volume of air is the key. I have built about 15 or so boxes in my day... I screw it together and use caulk or liquid nails to seal the inside seams.
I would carpet it too... if you leave it bare or just painted, wood chips might dirty up the trunk. Go to oreilly parts store and get the carpet that they sell for under the car (to lay on or use to keep oil off of the floor) and glue it to the box. It's not hard, just takes a little bit of time. I use hot glue, but spray glue might work... just cut it with a new razor blade/exacto/box cutter.
Also, I've tried fiberglass once... don't try it... it's a bear to mess with.
