IvoryJ30t wrote:ok, that amp will overpower one sub, but underpower both. if the subs were dual voice coil, i could have made it work. best bet is to run each sub to its own channel.
You're exactly right about the overpower/underpower part. I guess I have no choice but to go underpowered for a while then.
BTW, which component is causing the problem.. the amp, subs, or both?
Thanks for all your help dood!
Edit: You think I'll be better off bridging one of my subs than use both of em in stereo mode? What do you think?
Edit2: Nevermind, you already covered it in one of your posts. Hehe
