98240 wrote:you could probably search and find this but you are correct for bleeding you can use a friend to help you bleed or use speed bleaders
id did search several times, and found nothing and not jut on this site.
ddgsxr504 wrote:Where are you checking for leaks?? Run the entire length of the lines and check not just attaching areas like calipers and the such.
I F'ing hate ABS!
well when i checked the lines, my car was sitting for about 6 hours. i checked it today when i got home, and started to do the master cylinder. i noticed the rear passenger caliper was leaking BAD. so i returned the master cylinder and and ordered a new caliper. thanks for the help though guys.
