Need Help BIG TIME!
JC87HB
Car: 1987 Nissan D21 HB
ok so heres my problem.. i replaced my slave cylinder again due to a seal breaking and it was leaking fluid... well i went ahead and bought a replacement for the hi pressure hose that goes from the hard line(clutch fluid) to the slave cylinder... now when trying to remove the hose from the hard line, i rounded off the nut... where can i get a replacement hardline? and is there a way i can remove the old hose from the hardline even since the nut is rounded?? Thanks guys!!!
pejsa s-13
Car: 91 HardBody, 85 720
why didnt you use a line wrench and save yourself the trouble?
JC87HB
wtf is a line wrench... i tried using a 10mm wrench.. and man... that effed its world up!
JC87HB
ok... i see now... i was thinking of coarse... i guess its time to pick up a line wrench and go to a junk yard and get the line....
pejsa s-13
yea sorry to hear that. your best bet is to put some vise grips on the rounded off one and scrap it. then get another and invest in some line wrenches, this will save you alot of trouble my friend
JC87HB
yup going to sears tommorow then to a junkyard and grabbing a line... any clue on the size nut it is??
pejsa s-13
well you said its 10mm just get a small set
JC87HB
lol.. this is true.. hopefully sears has em... if not.. either lowes or home depot will.. xD
pejsa s-13
indeed good luck man
and if all else fails auto part stores EX. auto zone, checkers, advanced..... will have them without a doubt i would start your search there
