need help badly
Ca_laurier
cracked the endtank on my intercooler. since than i replaced the core, couplers, and clamps
Now what happens is when i start up the car it used to bog and than die out after a few seconds. at first i thought it was a boost leak from hell. hence replacing everything.
fuel pump was replaced with a walboro 255
now the car is getting spark, and the fuel pump is priming. i honestly have no idea anymore. HELP!!!!!!!!!
fuel filter maybe???
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
take your air flow meter off and blow air into the system only about 10 lbs. worth and go to looking for your leaks you've got a big ones somewhere.
