need help bad!!!
knmritz240
Car: 1992 Nissan 240sx se ka24det
hello i need a lot of help.. car is my dd. it shut off doing 60 and wouldn't start. put new dizzy in drive around block and againg fried?? put another in today and just took a s*** after trip around block what coold be doing this??
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Well you should follow the write up in the FSM on how to inspect and test the ignition system. but in a nutshell dissy tells ECU where the rotation is via 2 signal pulses 0 and 120 degrees. ECU sends signal to the power transistor which fires the coil to the rotor and out to the plugs. The ECU modifies timing based on conditions so although it is dissy during the rotor pad overlap there is time to compensate for timing advancement or retardation.
with that said follow the FSM and do some testing, could be the power transistor (coil), ECU, harness
