Need Help Bad.
lildwell
Car: 1995 Infiniti Q45a
My car wont move out of park. I tried to go to work and the shifteer wouldnt budge on my 95. I pressed the brake and nothing. The button wouldn't move. Whats wrong.
Probably a bad neutral safety switch.
There's a little port on the shifter surround - pry the little "cap" off it, and you can stick your key in it. This will release the shifter so you can put it in Neutral and start it.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
If you do't hear that relay click when you apply the brake, dead giveaway.
If you complete your profile, you won't have to post your car every time.
lildwell
I replaced all of the fuses in the fuse box because some were to large. Then, it worked fine. Thanks
Skibane
Car: 2000 Q45 AE 110K
EXCESSIVE FUSE SIZE: Them'll git ya every time!
