need help bad
dmorgan
Car: 1989 240sx-project car....R.I.P. 1991 240sx-daily driver...sold
1989 240sx-daily drifter
well i just got a new 240 and i had to replace some stuff on it and i was puttin it back together and i broke a header bolt off in the head. i was wantin to know if there was an easy way to get it out? it didnt break off flush it has very little stickin out but i just wanted to know if anyone had some same trouble and had some easier ways to get it out besides drilling it out and retapping it. any help is appreacited thanks.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
Is there enough to maybe get a vise grip or something like that onto it and twist?
tramp_drift240
Car: 1992 240sx SE Coupe
you should just get one of those easy out things.
it has teeth in the reverse pattern, so you drill into the broken stud, then stick that sucker in the drilled part and it grips the stud to pull it out.
then you wont have to re-tap the hole for another size or whatever.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
First stud on my exhaust snapped off to. Worst thing was it's almost 1/4 inch INSIDE the head.Just soak it in some kind of penetrating oil to loosen the threads up, punch the CENTER of the broken stud. Then very carefully drill a small hole. Then gradually increase size(this way you keep it straight so you don't fubar the threads). Then just jam the ez-out in the hole and reverse the drill. If all works well, it should grab into it, you'll get a nice crack sound as the stud comes loose and it'll back out just fine.
dmorgan
well thanks for all the help you guys and thanks for the advice on how to get it out.
