psyclone69 »
https://forums.nicoclub.com/psyclone69-u2025.html
Sun Feb 09, 2003 12:30 pm
Sorry for the long post,
Well heres my problem, I bought my 240 base model coupe, back in November, when I bought it, it had a clunking in the rear, and also a slight wobble in the rear end. In Decemeber I lowered my 240 with Koni yellows, and eibach sportlines. I also fixed the clunking porblem with PDM racings subframe align and lock, which fixed the clunking which was the subframe slamming back and forth.
So now it was lower, and suspension was stiffened and there is no subframe movement at all.
Now my car doesn't clunk but the slight wobble in the rear end, has become greater, it does it when I am driving at high speeds changing lanes, and also braking from high speeds. Before it wobbles when braking at high speeds, it almost feels as if the body twists before it wobbles. its not an up and down body roll type wobble, but a left and right type wobble.
I'm not sure what the problem is, but it feels unsafe to drive at high speeds. I know the things that are wrong with it right now, and I don't think thats causing any of the problems.
I don't have a rear sway bar, I have a 2 degree cross caster problem up front, but that should only cause it to pull to the right, and I have a busted drivers side tc bushing.
These shouldn't cause the wobble though. Does anyone have the slightest clue of what could be wrong?
Any help would be greatly appreciated.
