Need help bad........ Car is totally dead !!! going to junkyard
equetefue
Car: 2012 Infiniti M37s
97 GXE. Car started flickering panel indicator lights, and shutting off when I hit brakes and any kind of power load was applied.
Replaced battery and fix terminal wires, and car is dead. Not even the interior lights show signs of life. There is absolutely no ticking, clicking, lights, nothing....
Any ideas ?
Thanks
DaveVQ
Car: 2000 Nissan Maxima
Alternator which means it drained the battery and you will need a jump and you will probably make it only about 5 miles
equetefue
Thanks for the input, but it cant be the alternator cause I bought a brand new battery and still don't have not even the dome light to come up.
DaveVQ
have you checked for any codes, how about all the fuses and relays?
both the ones under the hood and under the dash by the drivers side left knee
equetefue
**UPDATE**
Reinstalled new battery and lights came up... What's up with that. ECU resetting itself ?
No sign of life yesterday with 2 batteries and 18 hours later all good ??? confused
Also I checked for codes since power came back and all I got is a 0505(nothing)
**UPDATE**
Car died again. No electrical power whatsoever... any ideas ?
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
It sounds like a short to me. I would take it to a shop bro.
equetefue
Yeah you might be right... It looks to be a bad ground, but I don't know where the grounding points for this car are located.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
This may sound dumb, but are you sure you installed the right battery?
They do come in "left" and "right" versions.
equetefue
ok...so I followed the positive cable coming out from the battery. There are leads coming out; one goes to the starter motor, the other to the main fuse box.
there's power all the way to the starter, power all the way to the fuse box, but nothing past that point.
So I guess my main fuse box went bad. Any takes or ideas ?
[TexMex]
Car: 2005 Nissan Maxima SE
most likely a relay or short. bad connection somewhere..start with the relays and work your way from there
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
I'd get a multimeter and starting check all of the leads in the fuse box. Could be a fusible link, fuse, or relay issue in the box.
