Towncivilian wrote:Have the engine codes pulled at an auto parts store such as AutoZone and post them here.
Do you run anything higher than 87 octane? If so, that may be causing your knock sensor code. Higher octane fuel is more difficult to ignite and the VG33E cannot advance timing far enough to take advantage of the higher octane; it was designed to run on 87 octane.
I went to both Autozone and O'Reilly tuesday and both hooked the comp to my truck. Both stores showed the bad Knock Sensor, and as well as a bad Oxygen Sensor(bank One). But, they did not show me a code. Also, I checked the link provided to me by a fellow replier. In so, I checked the fuse, which is a 7.5 amp, it was fine. This is leading me to think that I will need to either run it to the Dealership and let them hook it up to a better machine. Or, Try and locate the sensor and go from there. Also, I only run 87 in my truck, never any of the higher grades.
