Need help ASAP, What size are the bolts for the pressure plate on a s13 5-speed
Kraelic
Car: 89 240sx
I am in the middle of swapping out the automatic for the 5-speed and I had a flywheel and clutch kit with the bolts, it began to rain last night and I had to put things up in a hurry. This morning I had to pull that blasted automatic bushing from the crank, and finally got it out. Then I began to install the manual bushing, the flywheel, the clutch disk and the pilot tool, then got to the cover and I cannot find my pressure plate bolts anywhere!
Does anyone know the size of the bolt so I can run to Advance for some grade 8 bolts and lock washers? Or just the bolts and use some red threadlocker? I really want to finish this today. Thanks in advance friends.
