NEED HELP! ASAP
Jfundz
Car: 88 Nissan Maxima
I blew my engine in my 92 sentra se-r my friend has a 88 maxima im wondering if the 3.0 L VG30E fit my se-r need help
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
It would fit with a ton of fabrication. www.tigerjapenese.com and buy a motor for $500.00.
subzero27
Car: Nissan leaf
Nissan centra
An engine can blow up due to many reasons. One primary cause being overheating. Now that could be due to low coolant levels. In most of such cases you don't need a major overhaul. I suggest you take your car to an authorized mechanic and get it inspected.
Many a times a simple replacing the piston bearings will do the job but in more serious cases the engine has to be refurbished. You would be taking a chance and wasting money if you are looking for fitting a different engine. remember that all engines are made as per the car. The AC, power , handling and torque all depends on your engine and so the engine is a vital part of your car dynamics. Do not compromise on this.
You can have have a look at the nissan sentra specs here - http://www.nissanofstcharles.com/vehicl ... P0CL613002
Compare the specs with the specs of 88 maxima and you will clearly know the difference.
Hope this helps....
Jim
Chicago Nissan Dealerships
