NEED HELP ASAP!!!
ocska04
Car: nissan 240sx
So i have an s14 sr with a blitz twin disc clutch... so the throwout bearing goes bad and i replaced it alot with the clutch master and slave cylinder but the ones i got were some no name brand parts except for the bearing i got that from west co. nissan so i bleed the system and we i drove it for abot 20 miles and i lost complete pressure from the clutch so the master and slave gave up on me. So i get a new master from autozone and i got the nismo slave i pressure bled and manually bled the system couple times and i only have pressure but only about 1/4 to half of the pedal from bottom to top and i have no air in the system and the transmission wont go into any gears now... WHAT CAN BE MY PROBLEM ANY IDEAS BEFORE I DROP THE transmission...
S133P3R
Car: 1989 S13 240sx
check the pedal bracket? mine snapped and gave a really weird feeling of no pressure til about 2" from the floor and it wouldnt pop back up to the normal position.also, my cltutch pivot ball just snapped and caused my slave to pop out and spill all of the fluid from the master resevoir.good luck!
