My situation: Had the ca up and running for about 5-6 months now, idles great, runs smooth, and pulls hard. Just today I tried to start it and it started up but ran horribly, smoking white (fuel smells like raw gas) pull the plugs they are all black and wet with fuel. clean them up and install them, it idles for a second then almost dies and white smoke everywhere. so I suspect coil packs maybe and replace them with new ones ( around $220 from O'Reillys) same damn thing happends. I try to drive and it just smokes away but runs half decent when on boost.
My question: Im running standard everything except a arc smic, and a walboro 255 pump. Is this my stock FPR going out? or what. I've checked the ECU and no codes. also I can rev past 2.5k rpm so its not the maf.
P.S. This is my daily driver, I need it running ASAP
thanks soo much.
