need help asap
argento
Car: 240sx
ok car runs great...but only till about 3k rpm then no power/throttle. should be no leaks, MAFS wiring all lined up. any suggestions?
Modified by argento at 6:06 PM 8/17/2005
912.0turbo
Check voltage going to the MAF. Also double check your wiring.
argento
Car: 240sx
what should the voltage be?
argento
Car: 240sx
ok so the voltage at the MAFS is .8 then 1 at the ECU. so the wiring is good right? read another post about the MAF being backwards, but switched it around and the engine wouldn't even idle...so i'm kinda lost...
argento
Car: 240sx
any help? someone? please!
sil beer s13
Car: Kumori SPL S14
check your timing and for leaks.
argento
Car: 240sx
timing is set at 15 degrees. i'm starting to think it might be some kind of leak.
S13240
There's definitely a leak. My car use to feel like that with some ghetto rigged piping when I first did my very first sr swap five years ago.
argento
Car: 240sx
so after looking over the engine, they found one cylinder isn't firing(coilpack) could that be why there's no power after 3500 rpm?
argento
Car: 240sx
ok fixed the coil pack problem. lots of power, so my step dad says. see they own a shop, but in a different town...so now he's saying it might be the injectors, cause the motor sat for however long (car is still off ). i still think its a IC leak or they did something wrong, piping etc. i'll get some pics of the engine so u guys can hopefully point me in the right direction.
i just talked to my mom, she drove my car today, so shifting into 4th gear there is no power...
Modified by argento at 6:26 PM 8/17/2005
Nismo_Freak
Car: 89 Nissan 240SX
Next time please be more descriptive with the title.
argento
Car: 240sx
here's the engine
Modified by argento at 7:30 AM 8/18/2005
argento
Car: 240sx
argento
Car: 240sx
Modified by argento at 7:31 AM 8/18/2005
argento
Car: 240sx
spider_slayer
Car: S14 240SX
S13 240SX
pictures don't work...
argento
Car: 240sx
spider_slayer wrote:pictures don't work...
yea the pictures r too big to post. i ordered a greddy IC, so i hope that solves my problem. if someone wants to see my ghetto rigged piping leave ur email and i'll send u the pics.
