1bad91s13 »
https://forums.nicoclub.com/1bad91s13-u180852.html
Thu May 05, 2011 9:28 am
Ok so I've been trying to figure this out for 2 days now. I got my sr in and ready to start but fuel pump wasn't coming on. If I jump the relay the pump comes on and the car runs fine. But with the relay in its not getting the ground signal from the ecu. I tested from the relay all the way to pin 104 on the ecu harness with a multi tester and the line is good with no breaks. If I test pin 104 for ground right after the key is cycled it doesn't see any ground. I've come to the conclusion that its the ecu. But when I open it up I don't see any burnt components or anything. Anyone have any ideas? Bad solder joint? anyone know how to get the schematic for the ecu so I can test the resistors? Please help I really want to drive my car and don't want to buy a new ecu if I don't have to.
