NEED HELP ASAP! S14 5 SPEED SWAP WONT START! PLEASE HELP ASAP! PLEASE
9095240SXDUCK
Car: 240SXs
Ok
all wire to the tran is plug, start was running great before swap! And I have hot wire the first plug on the under hood fuse box! But the car won't start. and I am using the Org 96 auto ECU! Please Help ASAP! All its doing is makeing a huss sound for a sec or 2!
9095240SXDUCK
Car: 240SXs
also if I by pass everything and try to start it at the starter it will start!
InsanityInc
well, the system for the manual uses a clutch interlock switch that won't let you start the car unless the clutch pedal is depressed.
That's the only thing I could think of.
9095240SXDUCK
Car: 240SXs
we got it! My friend just hot wire some wire to something! LOL yep I have no idea what he did since I was inside the car 6 feet above the ground when he was under the car!
The the switch you talking about is kinda like the park switch on the autos! so that is why I had to hot wire the plug beside the U/H fuse box!
Thanks for replying!
KFL
Car: S14
Just curious how long it took you to do the auto-5spd swap. I'm about to help with 2 swaps and do my own very soon.Also drilling of the firewall to accomodate master clutch cylinder.
9095240SXDUCK
Car: 240SXs
I work a Tech at a Nissan Dealer so I use my lift! It took me a night (5-11:30PM) to take it all out. and another 3 hours the next night to put it all in! I had another guy that done this many times helping me both night!
tonynalli
damn dude..ok first of all.. there are 3 plugs on your fuse/ relay box.. the top plug you will need to jumper....only if oyu dont want to have a neutral safety switch then run two wires to the switch and figure out how to connect them to the pedal...other then that it will work....usually it takes me about...ohh 4 hours from start to finish to do a 5speed swap due to the fact that ive done then 1000 times....but god luck on your other swaps.
9095240SXDUCK
Car: 240SXs
LOL
This is my 1st 5 speed swap! So i know next time it would take me no more then a night!
