Need help ASAP! PLZ
TheJerseydude
Car: 1994 Ininfiti Q45
Im outside working on my 94 Q in the dark and this pulley that creates the tension for the power steering pump to operate isnt spinning properly. When I loosen the bolt it spins but when its on properly then it wont spin. Right now I put it on the bracket in this order: thick washer - Small plate- pulley - thin washer- big plate- bolt. is this the wrong order. please help asap and thanks in advance!!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
TheJerseydude
Thank you I really appreciate that fast response. Quick question though: Is that post I just looked at saying that I do not need the second dust cover that came in the box with the pulley from the dealership?
Infinitiguy19
Of course you need the dust cover, just look at the second topic to see how its set up.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Always consult the FSM first, then weigh any Forum advice accordingly.
TheJerseydude
In the pic it only shows one dust cover. In the box there were two; one for back of the pulley and one for the front. The pic only shows the front dust cover so I am trying to figure out if the back one is needed.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Paul Wall wrote:Of course you need the dust cover, just look at the second topic to see how its set up.
The 2nd link didn't talk about the correct sequence but the pictures in the first link are correct.
OP- Look at the pic's in Paul's link closely to make sure the pulley is not on backwards.
Modified by goody90q45 at 4:04 PM 11/9/2009
TheJerseydude
Ok I looked at the picture and did not see the second plate on there so I took it out and assembled it again and its working great, Im not quite sure of why the dealrship would give me a dust plate that I did not need but whatever I guess lol. Thanks all of you for your help and I really do appreciate it.
