need help asap please
fitzx4
so my problem is that my instrument panel went out on my 98 qx4. this occured while i was working on my after market headunit. i dont know the cause to the problem but checked the fuses by the steering wheel and on the left hand side under the hood.
!.) any clue as to the solution to my issue?
also if u guys are intrested i wanted to post pictures of my amp subs and headunit just not sure how to get them up
fitzx4
bump....sorry i seem pushy i just am pretty concerned about this
slickroger
Car: 2001 Nissan Pathfinder
is the whole panel dead?
or just a few lights out, or a couple gauges not working?
fitzx4
the guages themselves work fine. the lights are out on the gauges and on the gear sselector. all the indicator lights work such as seat belt cruise and odometer. in the day time you would never know there is an issue. so i dont understand what the issue could be.
Pwnin O'Brien
Maybe your illumination wire going into your head unit is being grounded? I would try disconnecting the entire wiring harness for the head unit and then see if any of the lights work then. Maybe the illumination wire is being grounded by the head unit case or something like that. Assuming you connected the illumination wire up to your head unit, if not, then I would find it and make sure it's not being ground by the chassis or another loose wire.
fitzx4
cool thanks so much i will do that after work tomorrow. i will post results.til then all ideas are greatly appreciated.
how do i post pics of what i have done to my q?
Pwnin O'Brien
You have to get an image hosting account and then you can post the pics on the forum. I suggest something like ImageShack.us for a free image hosting account.
Pwnin O'Brien
Were you able to fix the problem?
slickroger
you could have also turned the illumination wheel all the way down and not have noticed, this is known to happen frequently to people on here
fitzx4
yea the wire was grounded i was able to fix it the following day and im proud to say i wasnt out smarted by that dial...haha i would have been on yesterday but i was busy customizing my amp
fitzx4
W O T
Car: 2001 Infiniti Qx4
Just FYI, you have to put the / INSIDE the [ img ] code, right before the I, for your pics to work
fitzx4
fitzx4
haha well thanks anyways clearly i dont know what im doing
Pwnin O'Brien
You can insert an image using the following formatting (remove the period next to IMG)....
[.IMG] INSERT IMAGE HYPERLINK HERE [/IMG]
Your links are also dead, when I go the the pictures Imageshack says they don't exist.
Modified by Pwnin O'Brien at 2:28 AM 7/8/2009
fitzx4
fitzx4
the middle pic is my amp after i made a glass top and put blue led's in.power acoustik dvd/nav systempower acoustik bamf 2200w amp2 12" kenwood subs
fitzx4
i know my set up isnt thegreatest but really no one has any suggestion or compliments or creative criticism haha
02pathy
i like the deck fits just lovely, the style of the box perfecto mando, and the subs, only thing i don't like is u lol the height of the box it looks like it might interfere with ur truck lid it looks close
fitzx4
if you mean the pull over screen it wouldnt cover those. but its ok because i never had that thing. but hey at least you like me for what i have not who i am lol but thanks for the input
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
i dont see anything to critisize it looks great! my cargo cover just barely fits and ive got 2 10's. Power Acoustic components eh, that must have cost you! lookin good! the first pic isnt working, is that ur HU? id like to see. I'm moving to another town soon, if theft is lower in the new area maybe ill upgrade someday
fitzx4
Qxxx4 wrote:i dont see anything to critisize it looks great! my cargo cover just barely fits and ive got 2 10's. Power Acoustic components eh, that must have cost you! lookin good! the first pic isnt working, is that ur HU? id like to see. I'm moving to another town soon, if theft is lower in the new area maybe ill upgrade someday
the hu is the power acoustik ptid-7350nr since u say the pic isnt working. but yeah man coming from you that means alot becasue i like the way you have your q setup. as with anything cost can be cut if you take your time and researc before purchasing
