Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Sun Aug 10, 2003 7:15 pm
definitly a tension rod, you may have damage to the wheel/tire, and the strut depending on how bad it was, it could have also bent the front of your frame, although this is usually no big deal because nothing is attached infront of this. there is some other piece, sorry i can not think of the name, nothing expensive. might cost you around 400 total to get fixed, if you dont pull your own parts. if you find out whats broken you could do this. you could probably replace the parts yourself, but you will need an alignment after it is all installed. replace those tension rods with something better than stock! =)
the LCA was fine in my experience, so was the sway bar (unless there isnt one up there) id say impact was around 25-30mph, and just like you said the wheel was parallel with the curb on contact. the strut was also ok, but should be checked regardless.
those of you laughing at someone getting into an accident, havnt driven long enough.
