nissans13240sx »
https://forums.nicoclub.com/nissans13240sx-u37868.html
Tue Sep 25, 2007 4:36 pm
ok info on my car 91 240sx manual trans with 93 240sx motor in it. ok the problem is, is that it misfires almost all the time. when i am driving it lacks crazy power. It is the 3rd cylinder that is mising. I did a compression check 180psi across all 4 cylinders. I replaced plugs and wires. I replaced the distributor. I replaced fuel filter, fpr, tested all the injectors. used injector cleaner. also egr is not stuck open. replaced the o2 sensor as well. It is my daily driver and i really need to fix it becasue its so annoying. please help.
