rogoman »
https://forums.nicoclub.com/rogoman-u37451.html
Wed Aug 23, 2006 3:02 pm
There are two headlight retract relays, one for each headlight. One of them may be defective causing your problem. The relays are located in the 'relay box' on the driver's side of the engine up front under the air filter box; when facing the front of the car, the two relays are in the front row in the box, starting on the right hand side. You might try swapping them to see if the problem goes over to the other headlight.
