blubottlemax »
https://forums.nicoclub.com/blubottlemax-u3386.html
Tue Mar 29, 2005 5:18 pm
For a little over a week now I have been working on my KA-T project. I finally got it running yesterday, but with some serious issues. I had a SAFC and the 370cc injectors installed and running fine before the turbo install. Here was my setup:
T25SSAC manifold & O2 extension3" downpipe3" exhaust370cc injectorsZ32 MAFSAFCMSD BTMSMICrecirc valveLM-1 wideband2 step colder plugs, gapped at .032
With this setup, I had to run my MAF setting at 1in, 6out, or it would not run. This gave me the smoothest idle, but it still was missing and was not very driveable, bogging under a load.
Work done today: Reinstalled KA MAF, removed BTM and installed stock distributor, removed and reinstalled oil lines, double checked all fittings and connections.
Problems:1)Car will not idle correctly on SAFC setting 5in, 5out (correct for KA). Will only idle with 5in, 6out. With this setting, the engine runs really rich (12.4 at idle), with the stock KA setting, it runs really lean (16.7 at idle)
2)Engine stumbles and misses slightly no matter what the setting.
3)If reved above 3k, engine will die unless throttle is applied
4) While trying to set the timing, I removed the TPS plug, and the car shut off. It will not run with the TPS connected, just gets really rich and dies, so I cannot properly set the timing.
Any and all help is needed at this point. I tried moving the MAF farther away from the turbo, and it did nothing. I sprayed brakeleen around the fittings, and nothing. If I can't get this fixed in the next couple days, the turbo's gotta come off, this is my daily driver and it must be complete by next week.
