audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Sun Sep 09, 2012 10:16 am
Per the 2011 Versa owners manual:
"The Intelligent Key warning light illuminates green when the ignition switch can be turned. The Intelligent Key warning light illuminates red when the ignition switch cannot be turned. The Intelligent Key warning light blinks red if the Intelligent Key is taken outside of the vehicle while the ignition switch is placed in the ACC or ON position.
● If the Intelligent Key warning light blinks, make sure of the location of the Intelligent Key as soon as possible. The Intelligent Key should be carried by the driver while operating the vehicle.
● The Intelligent Key warning light turns off about 10 seconds after the Intelligent Key is brought inside the vehicle.
The Intelligent Key warning light blinks green indicating that the Intelligent Key battery is almost discharged."
