Need Help anyone know how to install 2 fuel pumps ????
rbtunner
Car: S14 240sx
Hello,
I going to be installing 2 external Bosch fuel pumps. I was wondering how i can do this setup any suggestion or know where i can find a useful artical. I was thinking of running the 2 external Bosch with stock fuel gas tank then running 2 fuel hoses to the engine bay. Also about the power to the fuel pumps what do you suggest tap into the stock ???
ThanksVwj
180fan
Car: 89 fastback
Fuel pumps:tap the stock tank at the lowest part one for each pump and one for return. Don't let your fuel tank go too low though. Those pumps are lubed by fuel.
Wiring:find the relay for the fuel pump and add another relay in a similar manner using the ignition as a trigger, run a seperate power line to the relay to the second fuel pump.
