need help again!!
bertini88
Car: 2003 Infiniti M45
2003 M45. i got it in march and right off the bat it started giving me issues when starting. i changed the ignition and starter relays and had been working ok for the most part but this morning after a weekend of a lot of starting issues, it wouldn't start and battery went dead. i jumped it and went on my way. when i got to work i restarted it 2 times and then it wouldnt start again. i here a lot of clicking coming from the center console area. everything lights up but when i turn the ignition either i get a ton of clicking or the battery sounds like it wears down and nothing.... someone help please!
svard75
Car: 06 M35x
Sounds like a battery issue to me. Got to autozone and have it tested.
bertini88
well that was the plan but i can't even start it now.... we tried to jump start it and nothing.
bejjutsu
Car: M35X ('06)
Please be specific in the title.
szh
Car: 2018 Tesla Model 3.
Definitely sounds like a dead battery - this is a common problem for our cars.
Look at the manufacture date on the top of the battery. If it is more than 3 to 4 years, then replace it for sure. This time, I bought a high-end Interstate from a local auto-parts store for about $120 (as i recall) instead of an OEM unit, and it works perfectly.
After about 10 years of ownership of my Y34, I have gone through 3 batteries, I think, and am now on my fourth - this time, it is non-Nissan, so let's see if it lasts better than the OEM units .
Z
svard75
Car: 06 M35x
bertini88 wrote:well that was the plan but i can't even start it now.... we tried to jump start it and nothing.
How did you jump? Was the other vehicle running? Did you have the cables connected properly? Did it turn over or same clicking sound? I would also look at the starter relays and have them tested. Do you have AAA? They can come to your home and diagnose the issue as part of the membership.
bertini88
well i tried to jump it again late yesterday and it would not get any charge. we checked it with a voltage regulator and it showed 12.4 volts.... but it would not start at all and after a few attempts went completely dead. we took it to an oreilly's and the test came back "bad battery" i would assume it was the original battery not too sure cuz i just got the car in march. i got a new battery and so far so good, i'm hoping this resolves the issue with the ignition problems i have been having.
thanx everyone for your replies.
myother45isalesbaer
Car: 2004 M45 Q70 awd,4.5
bertini88 wrote:well i tried to jump it again late yesterday and it would not get any charge. we checked it with a voltage regulator and it showed 12.4 volts.... but it would not start at all and after a few attempts went completely dead. we took it to an oreilly's and the test came back "bad battery" i would assume it was the original battery not too sure cuz i just got the car in march. i got a new battery and so far so good, i'm hoping this resolves the issue with the ignition problems i have been having.
I have not had your problem with my 2004 M45. But as other's posted I changed my battery to a non-OEM Interstate, top of the line battery which has so far been excellent. What you describe almost sounds like a guy I knew with a Corvette that I tried to help jump start. Turned out his battery was "dead" shortened out and I could hear my alternator whining trying to charge that battery. The cables got hot and I said enough before you burn my charging system out. There is no way you can charge a dead shortened out battery. Throw it out! Buy the best battery you can afford. Go from there. If the new big battery goes, you have other issues. It turned out at the end of the day my buddy with the Corvette had a bad ignition switch too. When I took it out, it fell apart in my hands. Replaced the ignition switch and with the new battery the ran car like new. He spent thousands in repairs before we back yard monkeys figured out what the real problems were.
Good luck.
