Ok I have a few questions that I REALLY hope someone will take the time to help me out with.
First off I have a 95 240sx with the factory-speaker shindig...I just finished installing my complete replacement package ordeal with the following: head unithttp://
www.cardomain.com/item/...=noneFront components:
http://www.cardomain.com/item/...=none Rear speakershttp://
www.cardomain.com/item/...=none4-Channel amp (50 watts rms x4 @ 4 ohms)
http://www.cardomain.com/item/ROCP4004
I have decided that I really dont need a sub-woofer. However I would like a little bit more bass out of the system. The only options I can think of are the following:
1) on the front components crossover there is a little switch that I guess is really a high pass a or low pass, it says in the infinity manual that if you put it on the "bass" mode that the woofer will expel more "bass sounds"
The only thing with this is that I not only want a little more bass from the rear to, but I dont want to give up the beautiful mids that these Kappa's are putting out.
2) there is also a high and low pass (crossover type ordeal) on the fosgate amp for both front and rear. So maybe if I put the rear on low pass they will put out lower frequencies and sound a little more "bassy"
3) There is also "frequency response" knobs for the front and rear speakers as well. So i assume I can turn they can make for a little more bass as well.
The only thing I really know about frequency is the lower the Hz number the more "bass" you get right? So what do you guys recommend me try to get a little more bass? Im not sure if I should leave the fronts alone and try to get more bass out of the rears (since the 6002i reference are supposed to be decent for bass, thats why i put them in back) OR if I should try to get some bass out of the fronts (I just dont want to lose my nice mids).
Thanks for reading the long post, any help is much appreciated. I just want to get this system sounding a little better so I can hear all the frequencies more. Its fuggin LOUD right now and I only have the gain (both front and rear) up to about 60-65% (so not even 50 watts really).
Austin
