well apart from materials - nothing,,,, i m an AC guy too
- towing company etc etc of my many biz'es
- all those top-ups in the stores are a COMPLETE waste of time n $$ - the efficiency of your system is a function of the amount of contaminants in the system, each time the gas expands and contracts overtime it absorbs moisture etc and loses its capacity to absorb heat. Add to that the moisture falling out under pressure and air, we have a system pressure made up of freon plus 'junk'. Its all the other junk in the system displacing your gas pressures that causing issue - think of it like your brake fluid grabbing moisture from the air - this can cause low and high pressure in the system - erratic movement of gauge readings. You need vacuum pump (mine yellow jacket - rolex of pumps), a gauge set and a tank of freon from your local sams club and your set - oh don't forget your safety glasses
then you-tube the rest, you sound like your smart enough to follow instructions
hope this helps - R
