RAQ45t wrote:Not really familiar with the Q45 tire and wheel combo,but would like to learn. Previously,managed successfully to lower an E34 BMW 5 series by partially using Eibachs,but used a 225/50/16(16x8" rim) tire instead of the 225/60/15 tire that came with the car.IF you use a very good rated tire("Z") or better as I did, the extra lowering aspect,AND the safety and handling work well.That car(my 20th BMW ,and 7th track car) was dead steady at 140mph with the cruise control on;didn't even change lanes.The car also ran well on track road courses,as I was a BMWCCA instructor.
Back when a friend of mine owned an 84 733i, I'd direct him to the BMWCCA web site to substantiate things I would tell him about his car. He wanted to upgrade to 15 inch rims and a wider tire. For some strange reason he wanted to put some 195/50-15's on his 7-series. I recommended that he go with 215/60's instead because it would be closer to the OEM spec tire diameter for obvious (to me) reasons. I believe that he was stuck on the on the "50" in the 195 and didn't understand why I was trying to undermine his choice, (forgetting that he asked me in the first place because of my general love for all things automotive).
He would continue to ask "Why 215/60?"
He was blown away when I parked my 88 200 SX next to his Bimmer and my 15 inch tires (stock 195/60), were shorter than his 14's.
I basically pulled my hair out trying to get him to understand that the first three numbers indicated the width of the tire and the next two, the aspect ratio or sidewall height. And so on and so fourth. He and some others I would talk to from time to time just didn't understand that tires came in different heights and widths specific to one rim diameter.
Basically to get the sidewall profile that he wanted he realized that he would have to go with at least 17's. He never got any aftermarket wheels for his 7 (no abundance of cheap wheels in the 5x120mm bolt pattern).
But he and others knew a BMW when they saw one (he didn't know what I meant by "twin kidneys" though).
I doubt that many BMW fans know about the Isetta or what the Roundel represents.
On the day I found and surfed around the BMWCCA site, in the links section I discovered the Powerdog tire size calculator.
It proved helpful as I often would have to get printouts to prove that the numbers on the side of the tire that I just calculated were correct.
Whew! That said RAQ45t, if you didn't correct for your adjusted diameter, you were only going 135.79 mph.
Danisiti 1
