marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Fri Oct 01, 2010 6:37 pm
Do the basics first.
1). clean all the connectors for CAS, PTU, injectors, water temp, coil packs. Get every bit of corrosion off them, and put some di-electric grease in them to seal out moisture.
2). check your fuel and spark by pulling the CAS (crank angle sensor) out from the left intake cam and while the engine is "on", turn it. Listen for clicks on each injector. Next check for spark on each cylinder. Pull the coil pack out, attach a spark plug, ground the body (not the tip) and turn the CAS.
3). Check compression. I hope that before that motor was put in a timing belt was installed? Either way, make sure you have good compression.
Report back what you find.
