need help!! 5 lug conversion... wheels maker with negative offset? without 4000$
ca20det
Car: 89 240sx 93 sentra
need your help on finding wheels that will clear my stock suspension in the front 17x9 +35 are far from clearing would need a 3 inch spacer or so... what wheel maker make some with 0 offset of negative?? that are not worth 4000$ a set of wheel???
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Sportmax. Buy coilovers first.
zeause
Cragar soft 8
TerminalVelocity
Car: 1996 240sx
You don't need zero or negative offset to clear. 17x9 +20 is known to clear just fine.
zeause wrote:Cragar soft 8
Haha I recently picked up a set to use on the rear for drifting. 17x9 -25 They way like 36.5lbs a piece though but I didn't notice a difference between my 17x10 fn's so
zeause
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Dont even mess with an offset like that. Are you talkin about sportmax or something? find some low offset secs wheels
ca20det
the thing is I got some 5zigen fn01rc and they will not clear the stock strut and since I do not have the money to buy both coilovers and wheels now and I got new boots and the shocks are 1 year old kyb gr2 with apex coils I don't want to sell them for 300$ because even with coilovers I will still have to put a 2 inch spacer to fit my 17x9 +35 in the front of my s13
ashibah83
Car: 93 SUPA BLACK COUPE
ca20det wrote: I don't want to sell them for 300$ because even with coilovers I will still have to put a 2 inch spacer to fit my 17x9 +35 in the front of my s13
you are TARDED, 17x9 +20 has been proven THOUSANDS of times over to clear even stock suspension all around, you've been told, take the advice, get some 15mm spaces, hell even 1/2inch which equates to around 13mm and put them on then quit b****ing
AZ89two4Tsx
2 inch spacer to fit 17x9 +20?!?! lulz
Someone has been filling you up with bulls*** info.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
hee hee hee hee hee
ZX88
Car: s13
gets some driftzzzzz wheels mang seriously you want your car to look cool your going to have to spend the money.
ca20det
ok thanks for the retard information and bulls*** you never read what I wrote so I'll get my information elsewhere thanks
ca20det
you should put on your reading glasses because It's writen 17x9 +35 and not 17x9+20
ashibah83
ca20det wrote:you should put on your reading glasses because It's writen 17x9 +35 and not 17x9+20
i had my glasses on idiot, 17x9 +35, +15mm spacer = 17x9 +20, stop trying to act like you know what your talking about, get the corn cob outta your A**, and listen, get some 15mm spacer and call it a day, DONE
ca20det
ok works for what you said but the thing you did not know is that I HAVE THE WHEELS AND I TRIED to fit them and the distance between the disc brake top and the strut is 3.5inch and the distance from where the wheel sits on the disc brake and the side of the tire is 6.5 inch so how can I with a 20mm spacer make the difference ??? there is no way I can so unless I can't read a tape mesure your supposedly thousand times proven to work is not relevent to my situation I guess
6.5inch= 165mm 3.5inch = 88mm165-88-20mm spacer = still need 57mm to mate the wheel to the disc brake surface
Drewster
Car: 1991 240sx
With a spacer as big as the one you want it seems like your wheels will stick out a lot. A 2 inch spacer is pretty big man...
ashibah83
that makes absolutely no sense, please try to explain that better so that someone may understand, so what your saying is that its 3.5in from your brake rotor to your strut, and its 6.5in from where to where?
if there is that much room then your wheels arent what you say they are
ca20det
the distance from the disc to (black painted part where the wheel sits) from the lower part of the strut where the spring sits is 3.5 inch the the depth plane of the picture
and the distance (back spacing on the picture )
is 6.5 inches
RMerritts
could always go with coilovers before the wheels.
ca20det
yeah I think I'll have to sell my stock suspension and loose a little bit of money and ride comfort on the street....
moulton712
Car: coupe, hatch, both s13s
i never like to bash, but if you want ride comfort why do you own a 240?
ashibah83
again get a 15mm spacer and youll be set, if it doesnt work ill pay for the spacers (im NOT kidding), just prove that your ish it what you say it is, wheel width and offset, there is NO way thet what your explaining is right unless something is SERIOUSLY wrong with your car
ca20det
I'll see about that because even if I hold the wheel in the position to put it in place it hits the suspension strut well before 15mm distance of the studs.. anyways no hard feelings about the argument I hope I'm just prime when people call me retarded its not like I'm a complete dumbass when it comes to car building as its displayed in my rebuild thread... with in mind that I am no mechanic nor an auto body specialist...
about the ride comfort there is a world between lowered 240 on sport springs and coilovers... whatever the coilovers and since I'm not going to drift every week-end the small comfort that I had with the stock suspension would have been nice !
