NEED HELP 1985 ZX
A home for 1983–1989 300ZX owners!
Glorywagon
Car: 1985 300ZX turbo
Hi all I have a 1985 300zx turbo automatic and a 1985 300zx non turbo automatic . 1-Will the transmission from the non turbo work in the turbo? 2-Is there any difference in the motors or will they inter change?3- Is it hard to change the didgal dash to an analog speed o meter.I bought the non turbo for parts car for the turbo. The turbo has a bad transmission. Thanks Danny
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
not sure if it's the same trans but you can definitely do the swap , worst case you'l have to use the N/a flexplate, torque converter driveshaft etc, the engine blocks are cast the same as far as I know, and I believe the digital to analog swap is a bolt in affair, I'm sure AZ_Zbum will pop in and clarify a bit
Glorywagon
the non turbo is a lot nicer car.What about putting the turbo on the non turbo?Would i need to change the conputer The tubo has new alum. ex. and 16 inch spook wheel. and body kit but raged out inside.Danny
Modified by Glorywagon at 9:28 PM 1/3/2007
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Check out http://www.z31.com for more info on the swap. With a donor turbo it is pretty straightfoward but it is not just an engine change. There are crossmembers that are different, bunch of other stuff to do, enough thta I never did it to my NA. You should read up on z31.com but with a full turbo I think your okay.
Not sure about the transmission, for sure the NA 5 speed and turbo 5 speed are different, the used a Borg Warner for the Turbo but not sure about the auto. You might ping a local Nissan parts counterman and ask him, they have factory remans and you can see if they are the same part numbers.
NissanSportMag(Z31)
Car: A few Z31s.
Glorywagon wrote:Hi all I have a 1985 300zx turbo automatic and a 1985 300zx non turbo automatic . 1-Will the transmission from the non turbo work in the turbo? 2-Is there any difference in the motors or will they inter change?3- Is it hard to change the didgal dash to an analog speed o meter.I bought the non turbo for parts car for the turbo. The turbo has a bad transmission. Thanks Danny
1. Yes. But probably not for very long. The turbos were a little beefier.2. Nothing major. Pistons, injectors, and some minor intake stuff.3. http://www.az-zbum.com/modific...shtml
If all that's wrong is the transmission and the interior, just swap those from the NA to the turbo. The transmission will probably hold up just fine on the turbo for a while as long as it is in good shape to begin with. But if the car is a parts car, it's probably not.
Swapping interiors should take a weekend at the most. There really shouldn't be any surprises in removing the old and swapping in the new.
Glorywagon
Ok I went to St Louis and pick up my parts car !985 zx non turbo 2 seater.this car was a one owner has the tool kit and every piece that it come with when it was new intior good not tore even the headliner is good.rust very little 225,000 miles.Doesn't run I thank it the fuel pump (not sure yet)the radio even works and the car talks.not bad for $225.00.
Anyway what problems will I have if I put the turbo engine in it? Like ECM wiring Danny
evildky
06 Nissan 350Z GT
you'll need the enging, harness, ecu and the front corssmember, it's easier if you can find a donor car
Return to “300ZX (Z31) Forum”
