Need headlight/HID wiring diagrams
Fieldy211
Car: 2001 QX4
If someone could post them, or have a link to where i can download them i would be greatly appreciated!
MIKEdetto
Fieldy211
Car: 2001 QX4
Its for a 2001 infiniti QX4 2wd.
Raxephon
Car: '04 RX8...for the moment...
Here are the headlamp wiring diagrams, you can find them in the Factory Service Manual (FSM).
If you don't have an FSM, here you go. 2001- http://phatg20.net/modules.php...d=220 2001.5- http://phatg20.net/modules.php...d=221
Fieldy211
Car: 2001 QX4
My LH low beam HID is not working. Everything else including brights work fine. The HID fuse USED TO keep blowing everytime i turn on the lights, untill recently (for some unknown reason, and the headlight still is inopperable.)
-Its not the bulb, swapped them out and still doesnt work.-Its not the Fuses, all are intact.-Its not the relays, both are opperable.
Question; im seeing NO resistance on terminal 7 (R/W) for the LH headlight relay, yet on the RH headlight relay i am seeing resistance on terminal 7 (R/L). What could cause an issue like this and could this be part of my problem?
Thanks ALL!!!MIKE
infinititech1
its the ballast...which is quite expensive...it happens ALOT on qx4's. the ballast shorts out which blows the fuse.
